Small bolts in head and retorque
  • shamal
  • shamal's Avatar Topic Author
13 Jun 2016 07:15
#731185
I have to finally retorque my head after rebuild.
I did 60 miles and the engine is SWEET.
i have a couple questions:
1: when i do a retorque i should loose the 5 small bolts between head and barrells? And the nuts between barrells and cases?
2: when i retorque the head, i think i have to NOT loose the stud bolts.just retorque in sequence. Is this OK?
I dont want to make a damage, the engine is fantastic.
1983 kz 550 h
  • rrsmsw9999
  • rrsmsw9999's Avatar
Re: Small bolts in head and retorque
13 Jun 2016 08:09
#731190
I 5honk 5he manual is specific here. Nuts then bolts. Do in order.loosen 10 degrees or so and torque to spec. I was suprise how loose they got on my 1000. All needed retorts. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • Nessism
  • Nessism's Avatar
13 Jun 2016 09:48 - 13 Jun 2016 09:49
#731204
I believe you should retorque all the head nuts and those 5 screws too.
Loosen the fasteners just enough to get them cracked loose and then quickly reverse rotation and tighten them to spec. Hopefully they will only need a small amount of tightening to come up to proper tension.
One time I rebuilt an engine using Athena gaskets and the torque fall off after running the engine was quite extreme. I had to retighten several times, the last time of which I noticed the base gasket extruding out of place. The crappy gaskets couldn't take the clamp load. I learned that Athena = garbage. Hopefully you used OEM Kawasaki gaskets.
Last edit: 13 Jun 2016 09:49 by Nessism.
The following user(s) said Thank You: shamal
  • davido
  • davido's Avatar
13 Jun 2016 11:35
#731219
Be sure to double check your torque settings.I used the Clymer manual and nearly met with tragedy.Wrong numbers.I realized in time though,which was lucky.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • shamal
13 Jun 2016 12:43
#731223
I have OEM Kawasaki head gaskets and orings. The cylinders base gasket is Not OEM but at this moment is fine, no leaks
1983 kz 550 h
  • Nessism
  • Nessism's Avatar
13 Jun 2016 13:17
#731228
shamal wrote: I have OEM Kawasaki head gaskets and orings. The cylinders base gasket is Not OEM but at this moment is fine, no leaks
Well, hope the base gasket isn't GREEN (Athena).
At any rate, torque them up. If the torque is way low you should plan on coming back in a few hundred more miles and retorquing again until you get stability between checks (no torque fall off).
Good luck!
  • shamal
13 Jun 2016 13:41
#731233
No isnt green. Its a gasket from a german brand , generico , i cant recall the brand name..
Color is Like a light brown-yellow. Typical gaskets paper.
OK i leave the bike in the garage for tomorrow. On the morning she will be cold and i will check the torque.
Ill let you know.
But is very so crytical this re torque procedure?
I can say the engine its at his best.
I read the Kawasaki manual , it Not mention nothing about loose and other things, it simply say after the first startup wait until the engine its cold and then thight again. And i think its referring about to stud nuts only
1983 kz 550 h
  • bountyhunter
  • bountyhunter's Avatar
13 Jun 2016 15:16
#731243
Nessism wrote: I believe you should retorque all the head nuts and those 5 screws too.
One time I rebuilt an engine using Athena gaskets and the torque fall off after running the engine was quite extreme. I had to retighten several times, the last time of which I noticed the base gasket extruding out of place. The crappy gaskets couldn't take the clamp load. I learned that Athena = garbage. .
Been there, did that..... base gasket disintegrated and came out.
  • bountyhunter
13 Jun 2016 15:18
#731244
Well, hope the base gasket isn't GREEN (Athena).!
If the gaskets are questionable, use them as stencils to make new ones out of good material. You can get good material at Auto Zone.
  • shamal
14 Jun 2016 09:53 - 14 Jun 2016 09:55
#731354
The base basket is almost out in the front side, on the left ... Uuuuh!!! I have no leaks so i think i was very very lucky.
I tried to retorque the head nuts but they did Not accept any rotation. The electronic wrench says 16.8/17 ft lbs in Evert nut.
Since the engine is perfect i think i will do nothing more..at the moment.
1983 kz 550 h
Last edit: 14 Jun 2016 09:55 by shamal.
