No tacho gear insert
  • Downzie
  • Downzie's Avatar Topic Author
11 Jun 2016 00:54
#730905
Hi guys
just trying to find some info on my bike i have installed a new kz550 1988 engine into a z500 1980 frame , the 1988 engine have not tacho gear insert , what type of tacho does this engine take? i have all z500 1980 parts and cant find any info on what tacho to install with a 1988 kz550 engine .
any help would be much appreciated
  • martin_csr
  • martin_csr's Avatar
Re: No tacho gear insert
11 Jun 2016 05:21 - 11 Jun 2016 05:23
#730913
It probably had an electronic tachometer. the Kawasaki electro tachs I've seen have a power wire, ground wire & sensor wire that connects to the black primary wire at one of the ignition coils. On some electronic tachs the sensor wire is wrapped around one of the spark plug wires, but I don't know anything about that type.
just throwing it out there. aftermarket speedometer gauge set w mech speedo & elec tach. ZRX 1995-2008
these are probably cheap junk. not sure, but likely. ??? .... oem meters might could be swapped in later. ???
PS: are you sure about the year of the bike? In the USA I think 1984 was the last year for the KZ550.
Last edit: 11 Jun 2016 05:23 by martin_csr.
