Starter clutch surprise
  • hfamracing
  • hfamracing's Avatar Topic Author
09 Jun 2016 19:58
#730763
Starter clutch went out, and I ordered the parts for the rebuild from Z1 Enterprise, got parts here, pulled off the assembly and found this. Any idea what this is off of? It does not have the roller bearings like the factory one and it fits different as well. I like this set up better that the stock one but im trying to get this fixed. Does anyone have any clue what this is from?
1327cc Wiseco Big Block
J head
Stock Cams
Welded MK2 Crank
AGP Turbo 50 trim To4E
AGP Wastegate
45mm Mikuni
Dyna 4000
MTC lock up clutch
Grimeca front and rear brakes
RC comp rims
  • hfamracing
Re: Starter clutch surprise
09 Jun 2016 20:02
#730764
another pic
J head
Stock Cams
Welded MK2 Crank
AGP Wastegate
45mm Mikuni
Dyna 4000
MTC lock up clutch
RC comp rims
09 Jun 2016 20:21
#730768
It's really hard to answer questions about bikes without knowing what kind of bike the question is about. PLEASE add your bike's year and model to your signature line; that way you do not need to remember to include that info in every posting. Ed
  • hfamracing
09 Jun 2016 20:30
#730769
I got this bike awhile back from someone else, so I don't know all the specifics of it. I will list what I know about it below. I dont know what year bike is, it is a stock engine cradle back halfed with a 9" tire.
Engine:
1327cc
AGP turbo
Dyna 4000
MK2 crank
1-2 auto J trans
MTC lock up
J head
Stock Cams
45mm Mikuni
Summit fuel pump and regulator
J head
Stock Cams
Welded MK2 Crank
AGP Wastegate
45mm Mikuni
Dyna 4000
MTC lock up clutch
RC comp rims
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Jun 2016 20:50
#730770
Pic of the engine might help if you don't know what kind it is.
  • hfamracing
09 Jun 2016 21:36
#730775
few engine pics
J head
Stock Cams
Welded MK2 Crank
AGP Wastegate
45mm Mikuni
Dyna 4000
MTC lock up clutch
RC comp rims
  • hfamracing
09 Jun 2016 21:37
#730776
another
J head
Stock Cams
Welded MK2 Crank
AGP Wastegate
45mm Mikuni
Dyna 4000
MTC lock up clutch
RC comp rims
  • zed1015
  • zed1015's Avatar
  • Away
10 Jun 2016 01:55
#730778
It's a KOKUSAN DENKI generator off another make /model bike with hopefully the same crank taper.
Could be off anything.
You need find what models the part number GP9326 fits.
I've googled it and come up blank so you may need to go to a dealer for cross referencing.
See the link for a pic of a similar roller assembly.
www.aliexpress.com/item/Free-Shipping-Mo...40010208.4.28.a80MiI
  • hfamracing
10 Jun 2016 08:34
#730817
Wow, you found that fast. Does it say what it fits? I am going to take it to a dealer today but kinda have a feeling they won't be able to figure it out either.
J head
Stock Cams
Welded MK2 Crank
AGP Wastegate
45mm Mikuni
Dyna 4000
MTC lock up clutch
RC comp rims
  • Nessism
  • Nessism's Avatar
10 Jun 2016 08:59 - 10 Jun 2016 09:05
#730821
I'm not sure what bike that one way clutch came from but Kawasaki started to use that style of clutch on some of their bigger bikes in the mid/late 1980's. Supposedly it's much more robust than the three roller/spring one way clutches installed on our KZ bikes. www.partzilla.com/parts/detail/kawasaki/KP-13194-1086.html
Last edit: 10 Jun 2016 09:05 by Nessism.
  • zed1015
  • zed1015's Avatar
  • Away
10 Jun 2016 09:30
#730826
hfamracing wrote: Wow, you found that fast. Does it say what it fits? I am going to take it to a dealer today but kinda have a feeling they won't be able to figure it out either.
The one in the link is for a Suzuki DR250 but they also list them for KTMs, Honda's, Yamaha's etc.
If no luck with a dealer the next best chance is to visit a breaker who will let you rummage his shelves till you find a match.
Are there any other numbers on the parts that can't be seen in the pics ?
  • hfamracing
10 Jun 2016 12:26
#730847
There are no other markings I saw. I will have to look once again. Thanks for the links, those are close for sure. I might just have to put stock stuff on til I can figure out what the heck this is from. It definitely seems more robust than stock and I would rather keep it the way it is.
J head
Stock Cams
Welded MK2 Crank
AGP Wastegate
45mm Mikuni
Dyna 4000
MTC lock up clutch
RC comp rims
