1974 KZ 400 no start- recent issue
  • the6nightmares
  • the6nightmares's Avatar Topic Author
09 Jun 2016 12:17
#730701
Hey folks, new member, been lurking for a while.
I recently purchased a 1974 KZ 400 in working order. It has been running, recently replaced the chain, cleaned, lubed and adjusted clutch and cables as well as a state inspection.
The bike has 19k miles- I have put about 100 on it.
When it runs it runs great. Here are the facts.
Brand new battery- installed by me within the last couple weeks
Has been running- would fire by kick start or electric start
When the key is on, headlights, horn, directionals all work
The issue- It will not start either by kick or electric.
It had been running, driving etc, came home parked it, wiped it down, pulled it out of the garage the next day and it wont fire.
The starter motor turns- makes all kinds of noise when the button is pressed, just doesn't seem to be catching.
I have checked spark- pulled plug and grounded to engine- visible spark- fuel in tank and in lines, checked carbs, has fuel
Any suggestions or advice would be great. If need be I can upload a video.
I am somewhat mechanically inclined, although my experience working on 40+ year old bikes is minimal, as I am more of a automotive tinkerer.
Thanks in advance!
1975 KZ 400
  • the6nightmares
Re: 1974 KZ 400 no start- recent issue
09 Jun 2016 13:55
#730713
interestingly enough, shortly after posting this and continuing to mess around with the bike in the garage it fired up. After doing some more research based on performance, and sound it may be the starter motor starting to go. As far as the no kick start, guess I just wasn't prodding her hard enough.
1975 KZ 400
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
10 Jun 2016 03:56
#730786
You may want to go thru the carbs and make sure they are clean. Also should check/replace the points, wires, plugs
Once these little darlings are in running nick they are pretty reliable. Mine will sit for six months and usually start right up.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • diggerdanh
  • diggerdanh's Avatar
10 Jun 2016 10:57
#730834
ThatGPzGuy wrote: Once these little darlings are in running nick they are pretty reliable. Mine will sit for six months and usually start right up.
Exactly. I just started mine up yesterday for the first time since November and it fired right up and I took a lap around the block. It's running well. (I did run the carbs dry when I rode it last and topped off the tank. I drained out the old gas a couple weeks ago - ran it in my mower - and put fresh gas in it)
  • the6nightmares
10 Jun 2016 11:14
#730838
Good suggestion on the carbs, but once it is running it runs fine. It does have new plugs, and looking at the points they appear to be OK, but it never hurts to follow up on older machines.
1975 KZ 400
