oil flowchart question
- shamal
06 Jun 2016 10:24
just curious to know if i should see oil ''return flow'' in the oil glass window while engine is running and i give some gas.
this is because before i had the rod disaster problem, i saw this happen, after the rebuild i see only the oil being sucked by the pump when i start the engine, and if the engine is running the window is empty.
i hope my english is understandable :blush:
1983 kz 550 h
Re: oil flowchart question
06 Jun 2016 14:04
Oil is not visible in the window while the bike is running. If you are concern you might want to find the thread about adding an oil pressure gauge to your engine. You can always install it and then remove after you confirm the oil pressure is good.
