It was fun, good luck
  • punisher11b
  • punisher11b's Avatar Topic Author
30 May 2016 08:47 - 31 May 2016 05:27
#729214
- good luck
Last edit: 31 May 2016 05:27 by punisher11b.
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: 440 overheat damage
30 May 2016 16:27
#729269
Rod bearings should be checked.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
The following user(s) said Thank You: punisher11b
  • missionkz
  • missionkz's Avatar
30 May 2016 16:59
#729272
I'd say you have a case of which came first, the chicken or the egg!!!
Your exhaust valves and respective seats were going bad first ...super heating the head, valves, valve seats, guides and or seals. Burning them up with +1500 degree exhaust gases.
Probably all of the above were damaged
Normally this is caused by normal wear and tear ...with very little maintenance in regards to checking and setting proper cam lobe clearances!
So my gut is telling me you shot yourself in the pocket book.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • punisher11b
30 May 2016 18:32 - 31 May 2016 05:25
#729284
- good luck
Last edit: 31 May 2016 05:25 by punisher11b.
