Timming for KZ1000
  • WILLIAM PIPPEN
  • WILLIAM PIPPEN's Avatar Topic Author
Timming for KZ1000
24 May 2016 07:55
#728230
Can someone walk me thru on how to time it with a test light. It has Dana coils & ignition. I understand the part about moving the points plate for 1 &4 and how to do 2&3. The way we do it with a timing light.
Were to attach and or use the test light is what`s confusing me.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Timming for KZ1000
24 May 2016 08:02
#728234
Use a timing light to set the timing. It is set at full advance on the Dyna S, then lower the idle. Make sure the spark advance is free and lubed.
  • MDZ1rider
  • MDZ1rider's Avatar
24 May 2016 08:14
#728239
Typical timing light hook up is to the positive battery terminal, chassis ground (or neg. battery terminal) and inductive pick-up on the appropriate plug wire (1/4 or 2/3) of the timing you are setting.
