kz550 1988 leaking oil bottom casing
  • Downzie
  • Downzie's Avatar Topic Author
18 May 2016 16:57
#727310
hi just put my kz550 1988 engine into a z500 frame, the kz550 engine is leaking oil from the lower casing through some holes that look like some kind of mounting plate, i have blocked the wholes but what is meant to go here to stop this properly is it a sensor insert of some kind? i have to parts for this . photo attached
please help if you can i am a newby
Attachment IMG_1381-2.JPG not found
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: kz550 1988 leaking oil bottom casing
18 May 2016 17:39
#727314
I hope that's not for a oil cooler.
  • Downzie
19 May 2016 18:18
#727495
Thank you so much i beleive it is
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 May 2016 18:20
#727496
Don't run it like that. Might starve the engine of oil.
  • Downzie
19 May 2016 22:53
#727555
Cool i wont , had a z500 1980 but had to replace the engine to a kz550 1988 to there a few difference ,
Had to convert it from shaft drive to chain which took abit but thats all good now ,
Hoping to have her going soon but all these things keep poping up ,
Ill have to get and oil cooler now more $$$
The orginal engine went under flood waters and sat for a few years so was dead dead dead.
