What happens when I take this off?
  • tri650
  • tri650's Avatar Topic Author
17 May 2016 12:36
#727002
I found the source of my oil leak for my 82 Gpz 750. I know this is the secondary shaft bearing cap from the manual. Before I took it off I wanted to make sure oil would not come pouring out or stuff flying everywhere. I am assuming there is a gasket or seal that must be malfunctioning because I get a slow drip from this spot.
Attachment Secondaryshaftbearingcap.jpg not found
  • Nessism
  • Nessism's Avatar
Re: What happens when I take this off?
17 May 2016 13:52 - 17 May 2016 14:04
#727013
I "think" the bottom edge of the cap is above the oil level. You could always tilt the bike a little to the right if it's not.
BTW, the cap has an O-ring on it.
Last edit: 17 May 2016 14:04 by Nessism.
The following user(s) said Thank You: tri650
  • tri650
17 May 2016 13:54
#727014
Thanks. I am happy that I found the source and it didn't involve the pan. I'll check the o-ring.
  • JR
  • JR's Avatar
17 May 2016 15:59
#727032
I replaced that O ring last year. Lost a little oil in the process but had an oil change tray beneath so no big deal. Maybe 50cc.
Just took a minute or 2 to whip the cover out, replace the O ring and stick it back in again
  • tri650
17 May 2016 19:23
#727081
Just ordered a new O ring. Looks easy. That never happens!
  • GPzMOD750
  • GPzMOD750's Avatar
18 May 2016 04:15
#727141
tri650 wrote: Just ordered a new O ring. Looks easy. That never happens!
Famous last words.....
  • tri650
18 May 2016 07:09
#727181
Ha - I need easy. Many battles with this bike. Just one more thing to check off the list.
