1982 kz750 e3 output shaft?
  • Django89
  • Django89's Avatar Topic Author
13 May 2016 21:24
#726307
Would a 1982 kz75pe3 output shaft work with my trans 1983 kz750 spectre
  • Nessism
  • Nessism's Avatar
Re: 1982 kz750 e3 output shaft?
13 May 2016 21:47
#726309
Check the parts fishe and see if the part number is the same.
  • Django89
13 May 2016 21:51
#726311
Nessism wrote: Check the parts fishe and see if the part number is the same.
Where do i find one?
  • Nessism
  • Nessism's Avatar
14 May 2016 05:09
#726329
There are literally dozens and dozens of different dealership type companies that sell online. google will guide you. I use Partzilla but there are many others. You can even check part numbers on Kawasaki.com
14 May 2016 05:19 - 14 May 2016 05:23
#726331
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationLooks like they have different part numbers. Check these links. Ed
1983 KZ750-N2 Spectre tranny:
www.powersportswarehouse.com/p/Kawasaki#...0-N2-1983/080113B-13
1982 KZ750-E3 tranny
www.powersportswarehouse.com/p/Kawasaki#...0-E3-1982/080120I-13
Is this the one you need?
Last edit: 14 May 2016 05:23 by 650ed.
  • riturbo
  • riturbo's Avatar
14 May 2016 05:28
#726333
www.partzilla.com/parts/detail/kawasaki/KP-13128-1040.html
if you scroll down it tells what modes have the same parts
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
