kz440 a2 dies when warm won't restart
- Nebr_Rex
Re: kz440 a2 dies when warm won't restart
31 May 2016 18:39lewisdg192 wrote: this is killing me.
I backed all the valves out almost a full turn. could def hear them ticking when I was riding. didn't break down on me while I was out, but I specifically let it idle for a few mins then let sit for 10-15. it started the first time, thought all was well, let it idle again for 5 min shut down for 15. then nothing.
a full turn on a valve adjustment is more than enough for expanding metal right?
also, the 11th hour 2-1 alum manifold gets very hot
edit: compression when warm is even on both sides gauge saying somewhere near 120. all gauges read different. I don't think compression is my problem
as soon as the aluminum manifold gets heat soaked from sitting it won't start. plugs are dark black, but for the most part not burning any more oil. bike sat for years I'm guessing
Valve lash is .004 to .007. You are plenty loose. Check your timing. Ditch that 2/1 manifold. Find your self some vm 26/28s.
The manifols gets hot and then heats up the carb.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- lewisdg192
01 Jun 2016 06:11
I would really hate to spend the money on manifold and carb and not have it work, people have had this setup work fine in the past
manifold gets hot but carb still stays cool
- lewisdg192
04 Jun 2016 09:41
okay after pulling all my hair out I think I have located the problem. the pickup coil's resistance between pins when it won't start is infinity, and there is a reading in the Mohm range from each pin to ground.
now where on earth can I get a kz440 pickup-coil?
- Nebr_Rex
04 Jun 2016 19:41
ebay.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
