Oil Coolers
- markerdown
Oil Coolers
08 May 2016 12:30 - 08 May 2016 12:42
I'm still runing the old school small 80s type coolers. I think one is a lockhart and the other a derale. I've seen Zs on youtube with a lot bigger coolers, briaded lines etc etc, and am wondering what everyone else is running and maybe I need to upgrade. I'm in the desert southwest US and the intese summer heat is just brutal on air cooled bikes and humanoids alike.
The Need for Speed Never Dies
\\\\\\\'75 Z2 750
\\\\\\\'76 KZ900
\\\\\\\'73 Z1 900 restoration project
\\\\\\\'73 Cuda 340 restoration project
2018 Z900RS
\\\\\\\'75 Z2 750
\\\\\\\'76 KZ900
2018 Z900RS
Last edit: 08 May 2016 12:42 by markerdown. Reason: sp
Re: Oil Coolers
08 May 2016 16:07
Holley / Earls Coolers
13 row coolers Little over 100 bucks for cooler only, plus lines and adapters at rear of motor
See OMRs build . He is in Phoenix area
- kaw-a-holic
Re: Oil Coolers
08 May 2016 21:05
I'm running this:
www.jegs.com/i/B%26M/130/70265/10002/-1?..._49KK-SNgaAkP_8P8HAQ
mounted here:
I have not hit the summer heat in AZ heat so I may need to add a fan or two with a thermostat.
mounted here:
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- drmiller100
Re: Oil Coolers
09 May 2016 08:58
Hi,
I just bought a kz1100. It has a cooler up front behind the front tire which looks aftermarket, but it is not hooked up. a rubber line connects right side of the engine to something under the carbs.
Did the factory bikes have oil coolers?
How hot do they get without one? how do you know how hot it gets?
- markerdown
Re: Oil Coolers
09 May 2016 10:58 - 09 May 2016 11:05
Wow, I've never seen one mounted in that location before. Mine are all up front so they can get air flow from forward movement.
drmiller, depends on the climate you live in, but anywhere you live, keeping the oil cool is just added protection for your motor and extends oil lubrication life... Summer heat is brutal in the tropics and desert, so an oil cooler was always a must on my Zs.
\\\\\\\'75 Z2 750
\\\\\\\'76 KZ900
2018 Z900RS
\\\\\\\'75 Z2 750
\\\\\\\'76 KZ900
2018 Z900RS
Last edit: 09 May 2016 11:05 by markerdown. Reason: sp
The following user(s) said Thank You: drmiller100
Re: Oil Coolers
09 May 2016 11:10
If it's stock the Lockhart should be good enough. I bought one from one of our members. ZX7 I think. Had to open up the ports from 3/8 to 1/2" to be certain I have enough oil flow.
kzrider.com/forum/2-engine/600430-zx7-z1-oil-cooler
- drmiller100
Re: Oil Coolers
09 May 2016 11:58
so stock there is no oil cooler?
Is there normally a hard line between the two fittings? I wonder why the previous owner unhooked the oil cooler. and I wonder if he used appropriate oil line. Looks like heater hose.....
I'm in Idaho, which can get hot, but nothing like somewhere really hot.
Re: Oil Coolers
09 May 2016 12:28
Start your own thread where you can add pics of what you have.
- Tirefire Pat
- (2) 1980 kz1000 b-ltd,,h2-750 triple,sold.kz 550 ,
Re: Oil Coolers
09 May 2016 18:59
If I add an oil cooler to my 80 1000 b,do you need to increase oil level due to fact of oil leaving motor and returning thru cooler?? The ports that you connect oil cooler to,,what is connected to them prior to me installing a cooler???thanks for any input... Pat
Re: Oil Coolers
09 May 2016 19:06
You'll need the fittings to replace the oil rizer like I have in my thread. My cooler takes about 1/2 quart. I put the intakes upside down so the oil in the cooler wouldn't flow back into the engine. The one I had before, the oil light stayed on for a few seconds until the pressure built up. Now it's immediate. They changed the rizers on the later engines. Got a pic of what you have?
Re: Oil Coolers
09 May 2016 19:12
Correction. I ran the lines above the cooler along the back bones, then down in between # 1&2 and #3/4 carbs.
- Tirefire Pat
Re: Oil Coolers
09 May 2016 19:18
No Steve I haven't purchased one yet ,,have you heard good reviews about Earl's coolers? When I plan to install I'll throw up some pics,I plan on starting a project thread. Thx
