Misfire/bogging down
  • Brussel12
  • Brussel12's Avatar Topic Author
08 May 2016 08:20
#725176
Recently brought this bike and it's brilliant I love it! However when I'm cruising down the road and I open her up a bit in any gear she bogs down and what I think runs on one cylinder also out of one cylinder there is black oily sludge coming out the exhaust.
I did think it was a fuelling issue but I've checked and replaced fuel lines and stripped the taps
It happens if I open the throttle any more than a 3rd.
I was think piston rings/ oil seal gone and losing compression?!
Thanks in advance!
  • Nessism
  • Nessism's Avatar
Re: Misfire/bogging down
08 May 2016 08:57
#725182
I'd try some maintenance before assuming too much.
Valve adjust
Break down the carbs, soak in carb dip, replace all the O-rings
Vacuum sync carbs
New or clean air filter
Check carb boots and replace as needed
Of course, if your bike is modified all bets are off regarding the jetting.
