KZ1100 pinging
- 76KZ900
KZ1100 pinging
06 May 2016 21:22
Noticed pinging .. detonation under hard acceleration. I use 93 octane and its helped but hasnt got rid of it. Ive checked timing its spot on. Even the advance mechanism is working right. Bike has average compression psi with what im assuming is factory pistons.. Bike does have a dyna s ignition. Anyone else run into this and what did you do to correct it ? Thanks
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
76KZ900 (sold) regret
03ZRX1200R (sold) regret
83KZ1100 LTD Shaft
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
- missionkz
Re: KZ1100 pinging
06 May 2016 21:25
Sounds more like preignition to me.
Could be bad plugs but most likely carbon build up in the combustion chamber, valve heads or piston domes.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- daveo
Re: KZ1100 pinging
06 May 2016 23:24
I wonder if the gasoline brand has anything to do with it. My bike started running odd just after putting different gas in yesterday, and I noticed subtle pre ignition a couple times when pulling away from stops today. :pinch:
1982 KZ1100-A2/1170 sleeper 😀
Re: KZ1100 pinging
07 May 2016 05:35
Pics of plugs? Valves adjusted?
- VTEC
Re: KZ1100 pinging
07 May 2016 16:48
My worn KZ engine had a spark knock from carbon build up. I quieted it down temporarily (and periodically) with top engine cleaner. Tune-up in a can.
KZ1000-K2
ZRX1100
XR400R
ZRX1100
XR400R
- car5car
- Banned
Re: KZ1100 pinging
08 May 2016 04:44
Go to GM dealer and buy valve cleaning fluid.
96 Yamaha Royal Star
82 Yamaha Virago 920
Re: KZ1100 pinging
08 May 2016 07:34
Additives can and will harden rubber seals. There is no substitute for replacing them and using the right type of oil. If they are leaking, there is a reason for it.
Re: KZ1100 pinging
08 May 2016 08:49
Chevron Techron in a can is reputed to be good stuff. It wouldn't hurt to run some through the engine on the next few tanks (until the can is gone). You also might want to retard the ignition a little. With a Dyna S you may have the ignition advanced a little unless you checked it with a timing light at full advance (engine running).
- 76KZ900
Re: KZ1100 pinging
08 May 2016 10:02
Timing checked at full advance.. its perfect.. Carbon build up likely makes most sense. Thanks Ill go the sea foam route.
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
- missionkz
Re: KZ1100 pinging
08 May 2016 12:09 - 08 May 2016 12:10
I've never had much luck with any of those products when it comes to combustion chamber cleaning of an assembled and running engine.
I think a good and hot engine with cold water and rubbing alcohol mix sprayed in the open carbs, at medium low throttle might be just as good.
I found some combustion chamber cleaning fluid from Chrysler that worked well with the head off!! Nice stuff but messy.
Bruce
1977 KZ1000A1
1977 KZ1000A1
Last edit: 08 May 2016 12:10 by missionkz.
- KZB2 650
Re: KZ1100 pinging
08 May 2016 12:27
I've read good things about Gumout Regane mixed in the gas...... maybe that and the water spray trick too.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
