Broken spark plug. Tried Everything, need help
- murquiza
04 May 2016 16:52I'm working on a 78 KZ650, one of the spark plugs broke when I tried to remove it.
Attachment File_001.jpg not found
I've tried pretty much everything:
- PB Blaster
- EZ-Out #5
- Heat (MAPP gas)
- Impact Wrench
And it refuses to come out. I need suggestions/help, worse case would be replacing the head, but maybe it can be avoided.
Bikes:
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
Re: Broken spark plug. Tried Everything, need help
04 May 2016 17:14 - 04 May 2016 17:15
I wouldn't think about replacing the head. Take it to a machinist and see if he can remove it using conventional methods; most likely he will be able to get it out. If he cannot, find a shop that has a Metal Disintegration Machine (MDM) or does Electric Discharge Machining (EDM) and see what they say. Either of those methods may be worth doing although MDM may be your best bet if conventional methods don't work. Ed
Last edit: 04 May 2016 17:15 by 650ed.
The following user(s) said Thank You: murquiza
- murquiza
04 May 2016 17:58
Just checked about MDM and that thing is brutal! (I need to have that!!!!!) I'm checking with machine shops in the area to see how much it would cost (A head out of eBay ain't expensive). Anyway, the engine will have to come apart, because it spins partially.
Thank you Ed.
Thank you Ed.
Bikes:
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
- DFIGPZ
05 May 2016 08:55
Pull head have to drill it out and install insert not a bad job.
1984 750 Turbo
- murquiza
05 May 2016 13:14
Just found a shop that can do it. If they can't salvage the thread they will put a plug and tap it.
Time to open that engine!
Bikes:
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
- Kidkawie
- I bleed premix
05 May 2016 13:20
If you can drill/grind the wall of the plug thinner you can try chipping out the remaining threads and save the original threads in the head.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
