KZ400 fork seal replacement
  • Oldercrow
  • Oldercrow's Avatar Topic Author
29 Apr 2016 05:03
#723583
I got some new fork seals and a fork seal removal tool from Z1 but when I removed the forks I got stuck on the part where you have to use a long hex/socket to hold the inner bolt while removing the hex/allen bolt from the bottom of the forks.
I ordered a long 36" set of socket extensions. Does anyone know if the inner bolt is a 6mm hex like the bottom or a 19mm socket like some have suggested?
Thanks for any information!
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
Re: KZ400 fork seal replacement
29 Apr 2016 05:16
#723584
The best thing to use is an impact. If you don't have access to compressed air I've heard the electric impacts will work too. Never tried one...
I've also used a piece of broom handle wedged into the inner bolt in a pinch...
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
29 Apr 2016 05:16 - 29 Apr 2016 05:17
#723585
Take a look at kzrider.com/forum/21-tools/318027-budget...linder-holder#318027 for some info about holding the fork cylinder. If yours is like mine it does not have a hex depression. Another option is the center top tool at this link: www.racetech.com/page/id/70 Ed
Last edit: 29 Apr 2016 05:17 by 650ed.
The following user(s) said Thank You: Oldercrow
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
29 Apr 2016 07:40
#723594
Leave the fork cap and spring installed and attempt to remove the lower bolt. The spring pressure holds the damper. If the bolt still spins try compressing the fork a little while removing the bolt. I always crack the bolt loose with hand tools first then go to the impact.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
