Kz900 / kz1000 head
- JDRAKE4200
Kz900 / kz1000 head
21 Apr 2016 20:18
Hello all. So, I have torn into the engine due to second gear being bad. I really think it is just bent shift fork, but I want to make sure she is 100% so I am going to upgrade while I have her open. Got a back cut tranny, welded crank, stainless valves..... But, I found a major problem that I didn't see when I bought the bike. One of the exhaust bolts is broken off, and there is no room to tap and use an Allen head bolt. I need a clean head with no broken fins, and no begin exhaust bolts. It can be completely stripped..... I need your help guys, there are none on eBay, and I know someone on here has one laying around they aren't using. Here is the kicker....I need to get it cheap. The wife is PISSED about how much money I have spent on this bike. If anyone can help, it would be greatly appreciated.
Keep the shiny side up!!!!
1976 KZ900 LTD
2004 Sportster 1200 Custom
1981 KZ550 LTD
1994 GSXR 750
1976 KZ900 LTD
1981 KZ550 LTD
1994 GSXR 750
Re: Kz900 / kz1000 head
22 Apr 2016 03:34JDRAKE4200 wrote: Hello all. So, I have torn into the engine due to second gear being bad. I really think it is just bent shift fork, but I want to make sure she is 100% so I am going to upgrade while I have her open. Got a back cut tranny, welded crank, stainless valves..... But, I found a major problem that I didn't see when I bought the bike. One of the exhaust bolts is broken off, and there is no room to tap and use an Allen head bolt. I need a clean head with no broken fins, and no begin exhaust bolts. It can be completely stripped..... I need your help guys, there are none on eBay, and I know someone on here has one laying around they aren't using. Here is the kicker....I need to get it cheap. The wife is PISSED about how much money I have spent on this bike. If anyone can help, it would be greatly appreciated.
no room to tap --
- z1kzonly
22 Apr 2016 10:24
Your type is not clear? Do you mean an exhaust stud is broken off flush with the head?
Early 6mm or later 8mm?
Have a picture?
I can even find a junk head on here. I have a couple I am welding up. All my good heads are sold.
The last 2 I sold had exhaust stud area welded up.
Find a good machinist, they can get it out, or a shop with an EDM machine for burning out broken parts.
Have a picture?
- car5car
- Banned
22 Apr 2016 12:01 - 22 Apr 2016 12:02
Bring head to automotive engine shop.
If you need to weld aluminum, not so long time ago I paid $125 to repair block hole about 2"x4".
Post picture here.
Post picture here.
96 Yamaha Royal Star
82 Yamaha Virago 920
Last edit: 22 Apr 2016 12:02 by car5car.
