85 GPz 750 Cam Covers
  • ajsfirehawk
  • ajsfirehawk's Avatar Topic Author
19 Apr 2016 09:09
#721783
I spoke to APE yesterday about covers that go on the reed valves on top of the cam covers. They only make them with fitment for 750's up through 1981. Anyone have a similar alternative solution?
80 KZ1000 Z1 Classic
83 KZ1100 LTD
18 Z900RS
23 Mach 1
  • Nessism
  • Nessism's Avatar
Re: 85 GPz 750 Cam Covers
19 Apr 2016 09:11
#721785
It would be quite easy to make your own out of 1/4" plate.
  • DurbinCR
  • DurbinCR's Avatar
19 Apr 2016 14:28
#721870
I have a water jet at work that I used to cut out new plates for mine just the other day, Going to paint them and made some custom decals to put on them that say "GPz 750." I'll take a couple pictures when I get home and ad them on here
1983 GPZ 750 A1 Unitrack
The following user(s) said Thank You: undiablo
  • ajsfirehawk
22 Apr 2016 18:33
#722449
I would love to see them Durbin. I don't happen to have or have access to a water jet cutter. B) But I'd like to see what you come up with.
83 KZ1100 LTD
18 Z900RS
23 Mach 1
  • DurbinCR
  • DurbinCR's Avatar
22 Apr 2016 19:16
#722456
I tried to put pictures on here but it said the image was too large. I don't know how to compress it
  • martin_csr
  • martin_csr's Avatar
22 Apr 2016 19:43 - 22 Apr 2016 22:37
#722464
The Ape Racing fitment guide seems to be lacking. If their block-off plates fit the 81 750 Ltd, then they'll also fit the 82 & 83, as well as the 81-83 650-CSR --- all those models have the same valve cover caps & reed valves. The reed valves are the same on all of the 650s that had them & all of the 750-4 models. I would have thought the caps, and hence the block-off plates, would fit the same, including the ZX750, but maybe they don't. ??? I would compare valve covers photos on eebbaayy.
Last edit: 22 Apr 2016 22:37 by martin_csr.
