HELP with clutch installation... newbie
- alexanderdd
12 Apr 2016 12:12 #720551
by alexanderdd
HELP with clutch installation... newbie was created by alexanderdd
Hey guys,
I don't know too much about motorcycles, but I do a little work here and there. My clutch cable on my 1980 KZ1000E (shaft driven) was fraying, so I bought a replacement. The first replacement snapped when testing, and now I have the second replacement on.
1) I know I need a new cotter pin before moving forward, so there's that. Will a paperclip work in the meantime?
2) How do I adjust that screw and nut properly? As you can see when I pull my clutch handle in, it isn't engaging/disengaging properly.
At a loss as to what I need to do to make this work. I just want to ride again Thanks in advance for all your help, seriously.
- Thank you received: 2749
12 Apr 2016 12:37 #720556
by SWest
Replied by SWest on topic HELP with clutch installation... newbie
Do you have a manual?
- QCkaw
- 1978 KZ650-B2
12 Apr 2016 13:12 #720561
by QCkaw
Replied by QCkaw on topic HELP with clutch installation... newbie
The 650-B2 has a spring that's between the cable eyelet and clutch release lever, as seen in attached pic (note that this model the release lever is mounted to the backside of the engine sprocket cover whereas your's appears to mount directly to the engine). The spring compresses whence the clutch is pulled; and when released, the spring helps push the lever back to start. The cable runs through the middle of the spring.
Definitely try and get a hold of a manual for your specific model.
The following user(s) said Thank You: alexanderdd
- rrsmsw9999
- Thank you received: 67
12 Apr 2016 13:24 #720564
by rrsmsw9999
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Replied by rrsmsw9999 on topic HELP with clutch installation... newbie
I have a 1000E manual and can post the clutch adjustment section later today if ya want. BTW the nut on that bolt need to be loosened and you turn the screw with a screwdriver clockwise until tight, then back off a 1/4 turn and then tighten the lock bolt. You are pulling the clutch mechanism through its actuator. Stop if you don't understand, until you have the proper procedure. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- alexanderdd
12 Apr 2016 13:40 #720569
by alexanderdd
Replied by alexanderdd on topic HELP with clutch installation... newbie
That would be awesome, thanks for all the help everybody!
- rrsmsw9999
12 Apr 2016 15:38 #720584
by rrsmsw9999
Here is the manual pages on the clutch cable adjustment.
R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Attachment KZ1000EClutchadjustFSM.doc not found
R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- RonKZ650
- Thank you received: 240
12 Apr 2016 19:04 #720620
by RonKZ650
Replied by RonKZ650 on topic HELP with clutch installation... newbie
You need the spring. The kotter pin is not necessary. I never put it back in and have replaced 20 cables or more over the years on KZs. The cable will always break the same way, fray at the lever. No adjustment other than cable inline adjustment should be needed if a new cable installed.
- alexanderdd
15 Apr 2016 16:32 #721131
by alexanderdd
Okay guys - update #1.
I totally forgot to put the spring back on, so I did that and got a new cotter pin. Got everything hooked up and realized that the metal arm (don't know the name of it) that goes over the bolt is shaped to match up perfectly with the rod that rotates (again, don't know the name, sorry).
However, I think the guy before me might have just mashed up the nut and washer against this rod so that it turned correctly. I can't get the rod to rotate to the correct position to have the metal arm swung out far enough to the right to make it work properly. I've uploaded some pics and videos. Can you all tell me what I'm doing wrong? Or if I need to fix that/how?
Thanks so much!
Thanks so much!
- alexanderdd
15 Apr 2016 16:33 #721132
by alexanderdd
another video
- alexanderdd
15 Apr 2016 16:36 #721134
by alexanderdd
pics, sorry for not uploading together (exceeding size limit)
15 Apr 2016 16:52 #721136
by SWest
There's no lock nut on that screw. The actuator arm fitts on that cam and hangs down. Do you have a manual?
- alexanderdd
16 Apr 2016 07:27 #721191
by alexanderdd
Hmm, I don't think there was a lock nut when I started, but maybe I misplaced it.
And can you be a little more specific? So is it hanging correctly in the videos?
And I thought I had a manual but I can't find it.
