Clutch adjustment on kz440 LTD belt drive
  • 1lowscort
  • 1lowscort's Avatar Topic Author
03 Apr 2016 11:21
#719050
Can anyone point me in the right direction to adjust the clutch on my 440 belt drive? Found instructions for the chain drive, but those don't seem to apply to mine. I've had the clutch basket apart and the frictions look to have lots of meat on them still, but I did not measure them nor do I know what the spec should be.
  • BornAgainBiker
  • BornAgainBiker's Avatar
Re: Clutch adjustment on kz440 LTD belt drive
03 Apr 2016 11:50 - 03 Apr 2016 11:52
#719052
Hope this helps. :)
Attachment kz440d-clutch-adjustment.jpg not found
All the best, Jeff
1984 KZ440 D6
Last edit: 03 Apr 2016 11:52 by BornAgainBiker. Reason: Made mistake uploading file.
  • 1lowscort
03 Apr 2016 12:00
#719054
Thanks for the reply. The cable is adjusted fine. Good free play and all, but the clutch slips.
  • BornAgainBiker
03 Apr 2016 12:03
#719055
Could be weak clutch springs.
All the best, Jeff
1984 KZ440 D6
03 Apr 2016 12:34
#719056
What oil are you using? If it is not JASO-MA compliant it can make the clutch slip. I'm a believer because it happened to me. Ed
  • 1lowscort
03 Apr 2016 15:31
#719071
I think I'm just running generic oil. Maybe I'll get some new springs and do an oil change.
03 Apr 2016 15:35
#719074
I suggest you look carefully at the oil containers when you buy for the oil change. If the container doesn't have "JASO-MA" printed on it you run the risk of ruining the clutch disks and making them slip. Most automobile oils (and all of them marked "Energy Conserving") contain friction modifiers that make wet clutches slip. Ed
  • martin_csr
  • martin_csr's Avatar
03 Apr 2016 15:55
#719078
Is your clutch release the same as in the pic posted by bornagainbiker?
  • 1lowscort
03 Apr 2016 16:17
#719086
Yes, it appears to be the same. Apparently the picture I have is too big.
