What is this part/Where does it go? 440 Rebuild
  • SvelteSoutherner
  • SvelteSoutherner's Avatar Topic Author
01 Apr 2016 13:05
#718711
In my haste to get the cases together before the 1184 had a chance to dry, I failed to notice that this plastic piece had fallen out. I think it goes here at the end of the drive shaft. What is its purpose? Is it essential? I does not seem to want to go back in place with the cases back together. Gracias.
Attachment IMG_20160401_112753454.jpg not found
Attachment IMG_20160401_112744645.jpg not found
Attachment IMG_20160401_112644559.jpg not found
Attachment IMG_20160401_112722548.jpg not found
1981 KZ440B
  • martin_csr
  • martin_csr's Avatar
Re: What is this part/Where does it go? 440 Rebuild
01 Apr 2016 16:28 - 01 Apr 2016 16:30
#718760
1980 440-Ltd crankcase diagram at Partzilla. 13045-1001 RECEIVER,OIL.
I don't know anything about it.
Last edit: 01 Apr 2016 16:30 by martin_csr.
  • SvelteSoutherner
02 Apr 2016 09:00
#718879
Thanks for the diagram. That at least gave me the correct orientation to jam it in place. The best I can tell is that it pools oil at the end of the shaft.
1981 KZ440B
  • KZB2 650
  • KZB2 650's Avatar
02 Apr 2016 11:01
#718896
Is that a sealer or glue to hold it or is it tore...... I have no idea on it either but I wonder if you outta see about a new one and make sure its on there right .... sounds like it does a important job.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
