kawasaki z 650 gear lever spline size
- Svendsen
01 Apr 2016 08:27
Hi i have changed a lot on my z650 also the gear lever to a system with gear lever linkage
Do anyone know what linkage would fit a z650? or what size the gear shaft pedal mount has?
Z650/ gsxr600 Cafézaki
- Svendsen
Re: kawasaki z 650 gear lever spline size
01 Apr 2016 08:28
The bike
Attachment cafézaki.jpg not found
- zed1015
01 Apr 2016 10:17
Looking good
Do you mean linkage rod or the splined arm.
Any Kawasaki and most Yamahas use the same spline and Yamaha R1/R6 use nice alloy ones (which I have used on a few Zeds) .
You will be lucky to find a link rod the exact size and again the Yamaha ones are quite long with plenty of scope to shorten and modify.
If you have modified the bike in the pic you won't have a problem modifying a linkage.
The following user(s) said Thank You: Svendsen
- Svendsen
01 Apr 2016 10:25 - 01 Apr 2016 10:32
Thank you very much!
It is the linkage i mean I will find one for a R1/R6
Last edit: 01 Apr 2016 10:32 by Svendsen.
