Is the cylinder block usable? It is bored +1 but..
- car5car
- Banned
24 Mar 2016 09:27
81 KZ1000J cylider block was bored 1mm over, but it is rusty and needs to get bored to next piston size. Can it be bored for +2mm pistons?
thanks. Are there +1.5mm pistons?
96 Yamaha Royal Star
82 Yamaha Virago 920
- zed1015
Re: Is the cylinder block usable? It is bored +1 but..
24 Mar 2016 11:13You will have to go 2mm O/S which is 1075cc.car5car wrote: 81 KZ1000J cylider block was bored 1mm over, but it is rusty and needs to get bored to next piston size. Can it be bored for +2mm pistons?
These are readily available from Wiseco and MTC via Pitstop performance (Joe Hooper) or APE etc.
Kits come with correct gaskets, circlips and rings etc.
Make sure you get the correct kit with 17mm pins NOT 18mm.
The following user(s) said Thank You: car5car
- car5car
- Banned
24 Mar 2016 14:54
Thanks, Zed!
Just to make sure, so no sleeves necessary, right?
- zed1015
24 Mar 2016 16:02
No sleeves. Just re-bore.
