82 KZ750 CSR Twin. Issues, tips, knowledge?
- KawiBunga
Re: 82 KZ750 CSR Twin. Issues, tips, knowledge?
28 Mar 2016 12:31Oldercrow wrote: I've been running my valve cover hoses into each other for a month. So far so good. Had to rejet for K&N air pod filters. I'm at 145 main and 52.5 pilot. Running sweet now.
I used this kit www.mikesxs.net/parts/yamaha-xs650-dyno-...le-jet-kit-for-bs-34
But ordered the 52.5 pilots from jetsrus.
OK cool, so I should be able to buy a rebuild kit with gaskets and all for the Yamaha with the same Bs34 carbs and should be good, Ive seen kits for the BS34 for Yamaha abd a few others and wondered if the could work with my Bs34 on the Kawi?
- Oldercrow
28 Mar 2016 12:32
I used everything but the plugs for the pilot. I tried them in but it wouldn't run. I found out that needing to use the rubber plug in pilot hole is year dependent and may or may not be required.
