Thoughts on Conical/Beehive valve springs kz440
- 13bravo
21 Mar 2016 20:26
I was just wondering if anyone has tried out a set of conical valve springs?
In theory the valve train weight should be less on the conical, and yes I know titanium works just as well in lowering weight.
I found that a 1.9L Saturn DOHC 91-98 year valve springs and retainers will work for a stock lift KZ440. Here are some specs. of what I have on hand.
A stock Kz440 retainer weighs 16 Grams while a stock Saturn retainer weighs 8.5 Grams.
Spring pressure that I have from the Kz440 are 28psi @ 1.335" while the Saturn is 62psi @ 1.330. Their was a slight difference in the assemble height between the different retainers.
My Kz440 springs coil bind at .967" while the Saturn's coil bind at .927
Pressure at coil bind for the Kz440 is 225psi and the Saturn is 243psi
1983 KZ440-D
- Nebr_Rex
Re: Thoughts on Conical/Beehive valve springs kz440
21 Mar 2016 20:42
Why do you want to change springs?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- 13bravo
21 Mar 2016 21:11
I see it as an upgrade since I already have it apart and have lots of Saturn parts that I've collected over the years.
It's going to be on hold because I have to find either a decent set of std. cylinders or some oversize pistons. It had a stuck ring on one piston and the cylinder has some water damage that only a boring and hone will take out. Minimum it has to go is .010 over.
I would do the 810cc piston but read another forum that it has a shorter compression height.
I'm a little picky on how the bore is.
1983 KZ440-D
21 Mar 2016 21:41
I don't understand what you are hoping to gain. A little lighter retainer wouldn't hurt, assuming the installed height for the spring won't change. I'm kind of doubtful that it would be though. The last thing you want is more valve seat pressure or more pressure at max lift. The stock springs are plenty strong enough so don't go stiffer unless you want to wear out the parts faster.
- PLUMMEN
21 Mar 2016 21:41
What is the free length of the springs compared to stock? Id be worried about the extra seat pressures affect on the stock valves/seats.
- Nebr_Rex
22 Mar 2016 02:2213bravo wrote: I would do the 810cc piston but read another forum that it has a shorter compression height.
Where did you see this?
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- 13bravo
22 Mar 2016 06:25
Assembled height is virtually identical between the retainers. It's within .005"
Open pressures are almost identical within 10psi of each other with the higher pressure being on the stock kz440 spring.
The extra seat pressure shouldn't affect anything very much, If the open pressures were extremely high parts wear would be very noticeable.
1983 KZ440-D
22 Mar 2016 13:5113bravo wrote: Assembled height is virtually identical between the retainers. It's within .005"
Extra seat pressure will result in the valve receding into the head faster than normal. NOT good.
- 13bravo
22 Mar 2016 14:32
Valve seats are soft?
1983 KZ440-D
22 Mar 2016 14:47
No. They do that normally, they don't need help.
- 13bravo
22 Mar 2016 18:52
Ahh got you. It's more like what I see with plow truck heads then.
1983 KZ440-D
- PLUMMEN
22 Mar 2016 19:53 - 22 Mar 2016 19:55Im talking about the free length of the spring before its installed. If its longer or shorter than the factory specd springs it could either have more preload on it from being squeezed together to fit on which will beat up other parts in the valve train from opening and being slammed shut harder.13bravo wrote: Assembled height is virtually identical between the retainers. It's within .005"
If its a shorter spring valves could float at higher rpms and tear up a lot of things.
Just saying.
Last edit: 22 Mar 2016 19:55 by PLUMMEN.
