Leaking at tach cable
- Topper
20 Mar 2016 08:45 - 20 Mar 2016 10:20
Well i think I found the culprit behind the growing leak ive been seeing at the tach cable on my 79 kz750.
This is the tach gear guide. Looks like some previous owner took a bite out of it. Ill replace this, the seal, o-ring and gasket.
BTW the shop manual is mum on how to remove this. That's because it's really easy. I thought I'd be picking at the seal for hours but the whole guide came out easily by just pulling on the tach gear.
Attachment 14584891891350[1].jpg not found
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
Last edit: 20 Mar 2016 10:20 by Topper.
- pete greek1
Re: Leaking at tach cable
20 Mar 2016 08:52
Easy , cheap fix,
Pete
Pete
- bountyhunter
20 Mar 2016 16:23
About 99% of the time, the leak is caused by an incomplete seal between the flanged lip on the cable piece and the corresponding flat surface on the mating tach drive piece. Once I made a gasket to seal that, I never saw the leak again.
- Topper
20 Mar 2016 16:29
Yeah there was no gasket at all. I don't like the look of that gouge in the gear guide. I think I'll replace all of the above. Parts are obtainable and affordable. So no reason not too.
1979 KZ750 Twin
1979 KZ750 Twin
