Stripped thread on engine mount bolt
  • Bowman
  • Bowman's Avatar Topic Author
09 Mar 2016 14:04
#714656
I see a long tedious session with a drill in my near future but maybe somebody here has some ideas.
When I put the engine back in after painting the frame I just snugged up the mount bolts (it was late autumn, wasn't going to really start putting it back together till spring. Today I took out the torque wrench to button it up properly and it was all good till I got to the lower rear mount bolt. Hell if I know how it happened but I can't get the nut to tighten or loosen. The bolt and nut just spin freely through the mount hole.
There's some thread visible (1/8" or so) at the nut end and I can spin the nut both ways with my fingers while holding the bolt head in place with a wrench. First I thought I'd sheared the bolt but I can't pull it out in two pieces and if I don't hold the bolt head steady with a wrench then spinning the nut just spins the bolt head. Flummoxed I am.
Honda 55 Trail don't ask me what year, 65? (sold)
79 Yamaha XS400 (sold)
76 KZ750B Twin (project)
72 Honda CT70 (project)
  • redhawk4
  • redhawk4's Avatar
Re: Stripped thread on engine mount bolt
09 Mar 2016 14:55 - 10 Mar 2016 10:50
#714657
Try getting something under the head, a screw driver blade or similar, so you can pry it in an outward direction while at the same time turning it anti clockwise. Sometimes you can strip the thread, but that doesn't mean it's free to just come out, but neither does it have the thread for it to unscrew.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
Last edit: 10 Mar 2016 10:50 by redhawk4.
The following user(s) said Thank You: Bowman
  • PLUMMEN
  • PLUMMEN's Avatar
09 Mar 2016 14:59
#714658
Picture of bolt and location? ;)
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Mar 2016 15:06
#714660
I'd lock the bolt in place and unscrew the nut while prying up with a screw driver. If you catch a thread you're home free.
  • Bowman
09 Mar 2016 15:15 - 09 Mar 2016 15:19
#714662
Hmmm... Maybe if I get an ally to grab the bolt head with a vice grip and pull like a mule I could get the nut to grab the thread and wrench it loose?
ETA no room or angle to get a screwdriver blade in. I'll post pics tomorrow when its light out if I'm still stuck. You guys are the best.
Last edit: 09 Mar 2016 15:19 by Bowman.
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Mar 2016 16:15
#714666
If you can tap on a screw driver enough to get under the nut and or lock washer, you might catch a thread.
  • Bowman
10 Mar 2016 08:48
#714732
Ungghh
Attachment P1020050.jpg not found
KZR to the rescue once more. Thanks guys.
  • rrsmsw9999
  • rrsmsw9999's Avatar
10 Mar 2016 09:46 - 10 Mar 2016 09:47
#714737
I did something similar. The lower mount bolts are different lengths. Don't put the longer one in the smaller spot. :ohmy: I stripped the nut right on the bolt while tightening to the engine stand. I chiseled the bolt and had one similar sized on hand. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Last edit: 10 Mar 2016 09:47 by rrsmsw9999.
  • redhawk4
  • redhawk4's Avatar
10 Mar 2016 10:48 - 10 Mar 2016 10:54
#714740
Bowman wrote: Ungghh
HOORAY!!! :) That's pretty close to how I imagined the state of the thread, based on the symptoms.
1977 KZ650B1
1980 Suzuki SP400
Last edit: 10 Mar 2016 10:54 by redhawk4.
  • Bowman
10 Mar 2016 13:59
#714758
It pays to marry a Saskatchewan farm girl. They think nothing of it when you ask them to hold this wrench and haul on this pry bar.
  • redhawk4
  • redhawk4's Avatar
10 Mar 2016 20:05
#714829
Bowman wrote: It pays to marry a Saskatchewan farm girl. They think nothing of it when you ask them to hold this wrench and haul on this pry bar.
I need to get one of those, do they sell them at Harbor Freight :)
1977 KZ650B1
1980 Suzuki SP400
  • pete greek1
  • pete greek1's Avatar
11 Mar 2016 10:36
#714916
I need 2, one to hold while the other one hauls, B) :laugh: :laugh: :laugh:
Pete
