Engine clicks.
- car5car
- Banned
Engine clicks.
04 Mar 2016 22:39
There is clicking sound every 2-4 seconds when engine is cold.
It is definitely not rattling chain.
Any ideas?
Thanks.
Any ideas?
Thanks.
96 Yamaha Royal Star
82 Yamaha Virago 920
- DoctoRot
Re: Engine clicks.
16 Mar 2016 10:02
take a screw driver and put the tip on the engine where you think you hear the clicks coming from. then put the screwdriver handle right on your ear hole. you'll have a better time determining where the sounds are coming from this way.
- car5car
- Banned
Re: Engine clicks.
16 Mar 2016 10:34
Thanks.
I use stethoscope
I use stethoscope
- strum
Re: Engine clicks.
18 Mar 2016 07:38car5car wrote: There is clicking sound every 2-4 seconds when engine is cold.
Any ideas?
Thanks.
not sure what your calling clicks but mine always had some noise and every time i would have someone listen they would say its normal.
but now that i finally got the carb tuning and spark advance dialed in most of what i was hearing is gone.
Blairsville Ga.
1980 KZ1000 Shaft (sold and missed already)
2003 ZRX 1200R (sold)
2003 Concours ZG1000 (just purchased)
- strum
Re: Engine clicks.
18 Mar 2016 07:40
Another thought is the valves could be clicking until heated up. i think this will be more pronounced if they have too much clearance.
Blairsville Ga.
Re: Engine clicks.
18 Mar 2016 07:47
Exhaust leak.
- car5car
- Banned
Re: Engine clicks.
18 Mar 2016 11:33If you are talking about popping, I have that too when I ride.swest wrote: Exhaust leak.
- strum
Re: Engine clicks.
18 Mar 2016 11:38car5car wrote:If you are talking about popping, I have that too when I ride.swest wrote: Exhaust leak.
if its popping then I assume its running lean,
when i got mine it cracked and popped especially when cold . and yep it was lean and had carb issues. now the popping is in the past.
also popping can be caused by leaking carb boots or other air leaks. and yes exhaust leaks.
Blairsville Ga.
Re: Engine clicks.
18 Mar 2016 14:01
Or carbs out of sync. One closed more than the others.
- car5car
- Banned
Re: Engine clicks.
19 Mar 2016 12:17I am pretty sure my bench synchronizing was not good enough. I'll check vacuum and type results here.swest wrote: Or carbs out of sync. One closed more than the others.
Re: Engine clicks.
19 Mar 2016 12:32
The clicks could be the air injectors you just capped off.
