GPZ750 sump question
  • cherrymetal
  • cherrymetal's Avatar Topic Author
02 Mar 2016 13:07
#713475
There's a stud sticking out of the sump, what is that for? I can't work out what attaches to it. I think mines damaged anyway and was planning grinding it flush before I send it off for powder coating?
_____________________________________________________
1977 Z650 (WIP - GPz750 Engine, RF400 Wheels & brakes, Bandit 600 Forks, Zephyr Swingarm)
1997 ZRX1100 - Stock - for now!(except for Hindle header with Micron carbon can)
1988 NTV600 Revere - Stock (work hack!)
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • cherrymetal
Re: GPZ750 sump question
03 Mar 2016 05:48
#713586
Ah ok. I'll have an aftermarket exhaust with the engine in a z650 so I doubt that mount will have a use. I'll go ahead and grind it off. Thanks!
  • Nessism
  • Nessism's Avatar
03 Mar 2016 07:22
#713607
cherrymetal wrote: Ah ok. I'll have an aftermarket exhaust with the engine in a z650 so I doubt that mount will have a use. I'll go ahead and grind it off. Thanks!
It's a broken threaded stud. You should be able to heat it up good and hot with a torch and then spin it out using some vicegrips. Some penetrating oil on the threads for a couple days before performing the extraction wouldn't hurt.
