- Thank you received: 1
Simple 750 motor mount question
- tri650
Attachment Mountinghole.png not found
Attachment Engienmount-2.png not found
- Thank you received: 2823
- Thank you received: 2829
Attachment 00003c-2-3.jpg not found
650ed wrote: To me it looks like you're doing it backwards. On my bike the nut is outboard; the bolt head fits in the engine slot. Ed
The bikes with the rubber mounted engine mounts (like this GPz) use a different mounting arrangement than your 650.
BTW, pretty sure I've got the mounting hardware you need tri650. PM me if you get stuck and can't find the nut.
- tri650
- tri650
Attachment IMG_1331.jpg not found
- tri650
tri650 wrote: Is this the correct nut?
Does it fit into the notches in the case?
- tri650
- Thank you received: 2749
swest wrote: Will the bolt head fit?
Good question. Try flipping the screw around the other way.
