Reed Valve cover 1982 GPz750
  • Madtrout
  • Madtrout's Avatar Topic Author
01 Mar 2016 04:32 - 01 Mar 2016 04:33
#713171
So I just got my 1982 GPz750 back together after a top end rebuild, and I noticed that the new gasket for the reed valve/breather cover is so thick that the metal cover is now 1/16 inch above the metal surface of the valve cover after proper torquing. The new OEM gasket is a thick cork like item. Is this correct? Seems like the one I pulled out was a thinner material. Should I leave out the gasket and just three bond the reed valve to the surface? Should I get rid of the entire crankcase venting
tube and just put a filter on the crankcase vent? Thanks in advance for your advice, Mark
Attachment IMG_1073.JPG not found
Last edit: 01 Mar 2016 04:33 by Madtrout.
  • TexasKZ
  • TexasKZ's Avatar
Re: Reed Valve cover 1982 GPz750
01 Mar 2016 05:51
#713181
I'd say forget about it and go ride the thing.
  • Madtrout
01 Mar 2016 05:51
#713182
Never mind! The old gasket was still in there, but it was so black it blended in and I couldn't see it. Mark
  • TexasKZ
  • TexasKZ's Avatar
01 Mar 2016 05:56
#713183
In that case I'd say pull the covers off and remove the old gaskets just in case they develop a leak.
