Z1R Turbo APE main bearing cap
  • mrdatsunturbo
  • mrdatsunturbo's Avatar Topic Author
  • mrturbo Norway
28 Feb 2016 22:36
#713011
Hi there
I started to do the APE main bearing support cap.
Crank is welded so i want to do this?
But in the instruction it says. After milling cap flat
Pick up bolt surface and cut it down .312" (7.92mm)
Please explain me what bolt surface is??
And also APE main bearing studs where to fit the two tallest bolts.
OEM crank bearing cap there is 4bolt same lenghts.Thanks from Norway :blush:
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Z1R Turbo APE main bearing cap
29 Feb 2016 05:43
#713020
Its the side of the cap with the ribs on it. :)
  • NakedFun
  • NakedFun's Avatar
29 Feb 2016 06:07
#713030
So the idea is, the tops of the four bolt holes that secure the bearing cap to the case, is where you would set you milling height to. Then you mill the arch looking ribs that extend upwards beyond that point so that you have a flat surface the APE plate brace can lay against and be bolted down to.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
29 Feb 2016 06:16 - 29 Feb 2016 06:17
#713032
here's one that has been machined.
Last edit: 29 Feb 2016 06:17 by 531blackbanshee.
  • mrdatsunturbo
  • mrturbo Norway
29 Feb 2016 06:44
#713039
It was the bolt surface who did some strange thing into my head.
Thanks a lot again, i will post the final result.Rune :laugh:
