Won't start after changing Shift Pedal Return
  • Tmiron
  • Tmiron's Avatar Topic Author
24 Feb 2016 11:52
#712330
My Shift pedal return spring broke and I replaced it with the help of this forum:
kzrider.com/forum/2-engine/592618-kz-400...-pedal-not-returning
I got the bike back together and adjusted the timing. It was starting and immediately dying so I adjust the timing again and cleaned the points.
It's getting fuel, has a strong battery, strong spark, clean air filter, but won't start. It's killing me because it's finally nice out and I want to ride.
Any Ideas?
1978 KZ400 B1
  • Kwaker2000
  • Kwaker2000's Avatar
Re: Won't start after changing Shift Pedal Return
24 Feb 2016 12:54
#712346
do you have a manual to help with the timing ,you might have adjusted it wrong ,was it running alright before you adjusted it
  • Tmiron
24 Feb 2016 13:18
#712348
Yep, I followed the manual to a T. Also, i'm getting good spark out of the plugs
1978 KZ400 B1
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
24 Feb 2016 16:14
#712365
Any chance you swapped the wiring to the coils.
You will still get spark, but at the wrong time.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
24 Feb 2016 16:19 - 24 Feb 2016 16:20
#712366
Check the adjustment of the points again.
Last edit: 24 Feb 2016 16:20 by 650ed.
  • Tmiron
26 Feb 2016 13:22
#712618
I check them again and read a few other posts about adjusting them. That was it and now it's running! The manual isn't super clear on the oder of operations but i Was able to get it going
1978 KZ400 B1
