Camshafts
  • Wasbigoso
  • Wasbigoso's Avatar Topic Author
Camshafts
22 Feb 2016 18:10
#712021
I might be running a z4 (420 lift) camshaft. Do I need to run shim on bottom tap pets?????
  • bluezbike
  • bluezbike's Avatar
Re: Camshafts
22 Feb 2016 18:15
#712024
Might help if you let us know what year/type bike/motor these mystery cams are on. :)
79 KZ 1000 LTD
  • gpz1170
  • gpz1170's Avatar
Re: Camshafts
23 Feb 2016 08:30
#712103
on a z1/kz 1000 you are right on the edge for going to shim under buckets. you could run shim on top but for safety reasons I wouldn't, too easy to spit a shim.
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
  • baldy110
  • baldy110's Avatar
Re: Camshafts
23 Feb 2016 08:36
#712106
Yes
  • DFIGPZ
  • DFIGPZ's Avatar
Re: Camshafts
23 Feb 2016 13:45
#712156
I have several sets of Z4's installed with SOT but........... there better be good springs CORRECTLY setup run valve clearance at .004in and keep an eye on everything
1984 750 Turbo
