- Thank you received: 3
Quick question
- hardr0ck68
- Who put the what in the where?
07 Jul 2006 23:24 #60128
by hardr0ck68
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
Quick question was created by hardr0ck68
If i were to use oversized rings would i need to track down oversized pistons?
This is for 1mm over rings (or aproxmatly .040" over)
Also what do i tell a machine shop when i go to get the block bored/honed? will they know what size to go up to if i just tell them 1mm over stock? Thanks guys!
Rocco
Post edited by: hardr0ck68, at: 2006/07/08 03:11
Rocco
1977 kz650 c1
- RetroRiceRocketRider
- Thank you received: 29
07 Jul 2006 23:30 #60131
by RetroRiceRocketRider
Replied by RetroRiceRocketRider on topic Quick question
Yes, you will need to use pistons that match the rings in sizing.
Most machine shops will want at least one (if not all) of the pistons and rings you plan on using so they can bore your cylinders to match the pistons/rings.
Hopefully Jay from APE will run across this thread to tell exactely how they do it there and what parts are normally required from a customer.
Post edited by: RetroRiceRocketRider, at: 2006/07/08 02:31
- steell
07 Jul 2006 23:46 #60135
by steell
Replied by steell on topic Quick question
1mm oversize is .040" oversize, and on most KZ motors that's the maximum oversize piston available.
- hardr0ck68
08 Jul 2006 00:14 #60137
by hardr0ck68
1977 kz650 c1
Replied by hardr0ck68 on topic Quick question
yeah sry steell i edited my typo in the origional post. Ok so now know i need both pistons and rings. Bummer. Well it will be fun to try and find them
1977 kz650 c1
- trippivot
08 Jul 2006 05:36 #60149
by trippivot
Replied by trippivot on topic Quick question
bad idea to use over size rings on std piston. but if you do you file the end gap until you have about .035~.040 when installed into cylinder. put it on the piston , build the engine and wait til it blows up.
Weisco pistons are a good replacement. get the cylinders to the machine shop have them clean up the bores before measuring. sometimes taper and barrel shape is deep. order pistons after "clean measurement" then you are assured to have straight cylinders and can set final piston to cylinder clearance and ring end gaps
