Muffler advice for a 4 into 1 system, KZ550
  • carwash
  • carwash's Avatar Topic Author
16 Feb 2016 16:54
#710990
I just picked up a set of 4 into 1 mac headers for my '81 KZ550. Now i need a muffler. What sort of things should I take into consideration? I like the look of the shorty (12") reverse cone that Dime City sells.
Also, there is no shortage of Ducati mufflers out there because first thing Ducati owners do is get a new exhaust. I think one of those larger canister looking mufflers from a Ducati would look good, any reason that wouldn't work?
any info and/or ideas appreciated!
1980 KZ550A
1980 CB750F
  • Nessism
  • Nessism's Avatar
Re: Muffler advice for a 4 into 1 system, KZ550
16 Feb 2016 18:33
#710998
Go for the Ducati muffler and post up some photos. :D
  • TexasKZ
  • TexasKZ's Avatar
17 Feb 2016 05:33
#711040
Two big considerations will be the inlet size compared to the size of the pipe you have, and you will have to fabricate a muffler hanger. Neither of these is a complicated problem.
If the back pressure of the new can is radically different than what has been on the bike, some carb tweaking may be needed.
  • carwash
17 Feb 2016 06:40
#711049
Probably going to get the headers powder coated, so I'd like to get the muffler, mounts, etc.. all welded up first.
I'm leaning toward the cone engineering reverse cone, not sure of length yet.
TexasKZ wrote: Two big considerations will be the inlet size compared to the size of the pipe you have, and you will have to fabricate a muffler hanger. Neither of these is a complicated problem.
1980 KZ550A
1980 CB750F
