1985 GPz750 Starter Issues/Questions
  • ayeckley
  • ayeckley's Avatar
Re: 1985 GPz750 Starter Issues/Questions
24 Feb 2016 19:02
#712390
So you are trying to start it with just the charger and no battery? That's the problem. A starter motor under load draws lots of current, easily more than 50A. You also run the risk of damaging the electrical system if it did start.
1976 KZ900A4
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1 aka GPz 750
1983 ZX750 A1
1973 CL350K4
1984 ZX1100 A2 aka GPz1100
1969 CT90
2006 Burgman 400
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Feb 2016 21:02
#712403
phonzie wrote: Hi, hope it's ok to jump in here rather than start a new thread...
I've just picked up a non-running '82 750 LTD.
The battery is shot so for the moment I have a 12v charger hooked to terminals.
Bridging the solenoid posts, the starter is spinning, or at least making a sound like it is doing something. I've taken it apart and cleaned it, brushes are in spec. Bench tested it and it spins fine, it's comparable with a different motor that I know to be working.
However, the starter is not budging the engine at all, though the engine turns freely with a 17mm socket on the crank.
The idler pinion is as per the manual - no movement clockwise, and moving smoothly and freely anti-clockwise. It is also moving clockwise by turning the crank.
There is no feeling of roughness or grinding with the idler gear, though there is a couple of mm (?) of runout. Is this acceptable ?
Appreciate any suggestions, thanks in advance...
You should start your own thread.
