engine mount nut won't go in nut shaped groove
  • blink543
  • blink543's Avatar Topic Author
14 Feb 2016 08:48
#710680
So I have my kz650 engine mostly mounted but the nuts that in the front mount that Go into the nut shaped grove won't go in. I have the engine in the garage so it's really cold outside and I'm thinking the aluminum shrunk so much that the nut won't fit now? I had bagged up everything before so I could keep it organized but these Damn nuts aren't going in. Strange. I tried finding a pic but I can't. And my phone is messed up.
Adam james
  • blink543
Re: engine mount nut won't go in nut shaped groove
14 Feb 2016 08:55
#710682
Adam james
  • Nessism
  • Nessism's Avatar
14 Feb 2016 09:13
#710683
Most likely you have the wrong nuts.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
14 Feb 2016 12:03 - 14 Feb 2016 12:56
#710702
Some 650s use a single long threaded rod for the front mounts, and some use the two separate bolts (approx. 4" long) and nuts.
The head of the bolt fits into the engine casting, coming from the center out, so you can install a nut from the outside.
Sounds like this is where you are having trouble, that the head of the bolt is not fitting the casting in the engine?
Maybe you are installing the bolts backwards, from the outside, and trying to put the nuts in the center/inside?
Install the bolts so the nuts are on the outside/left and right side of the engine.
2 short bolts on the front top mounting??? Isn't that supposed to be 1 long bolt?
The B1 has 1 long bolt; the C1 has 2 shorter bolts. Strange but true. LOL Ed
Both my B and D have two bolts at the upper front,(triangle plate). The heads on them index into a recess in the case. They run from the inside out with the nut on the outside. They're 10mm x 1.25mm pitch, to fit with case savers one is 65mm, the other is 95mm long.
[IMG
[IMG
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 14 Feb 2016 12:56 by rstnick.
  • KZB2 650
  • KZB2 650's Avatar
14 Feb 2016 12:25 - 14 Feb 2016 13:19
#710704
rstnick wrote: Some 650s use a single long threaded rod for the front mounts, and some use the two separate bolts (approx. 4" long) and nuts.
This what my parts break down catalog says for a KZ650B.
Front .......Upper left bolt #1 cyl....72mm long .............. Upper right #4 cyl.....46mm long
Lower left...... 84mm long ........ lower right same 84mm long
rear left 219mm long ....... rear right 250mm long. The other 4 rear bolts that hold the brackets on in the rear are 40mm long ..... Maybe your trying to fit one of these in the upper right front when you need the 46mm long one.
(Your picture Rstnick shows what I have on my bike).
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 14 Feb 2016 13:19 by KZB2 650.
