810 kit questions
- G-Force
810 kit questions
11 Feb 2016 07:43
I'm going to a 810 kit on my 83 kz750l3.Jetting stock.I know I need go up on jetting due running kerker 4 into 1 and the airbox mod(2 inch hole in bottom of airbox).Do I need go bigger on jetting due to the 810 kit.Thanks
Re: 810 kit questions
11 Feb 2016 09:18
I don't know the answer but I do know that rejetting a bike isn't as simple as just bumping the main jets a few steps. Getting a Dynojet kit is highly recommended since they come with a variety of jets and new needles which have more taper, which is critical to getting a proper mixture response though the midrange.
11 Feb 2016 12:59
Have you tried using the search function on this site? I'm pretty sure there are a couple of 810 builds and some threads about other 810-related stuff.
- redhawk4
11 Feb 2016 15:05
You really need to try it. The thing about a carb is the more air that's drawn through it the more fuel it puts in, so the jet size is a function of the breathing as well as the capacity. I'm sure someone has been down this route, but it needs to be the same setup in terms of carbs, airbox/filters and altitude etc. to be much help. I'm still thinking of doing an 810 on my KZ650B1, but I think if I do I'd just put it together with the carbs as they are and try it out, no doubt it would run, but then I could see where it might be weak with the bigger CC's and then adjust for my circumstances and setup. I can buy carb jets locally so it's easy to try it, then get what I think will work.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
1977 KZ650B1
1980 Suzuki SP400
