Is it ok to ride without the front motor mounts?
- YamaKawa
08 Feb 2016 07:23
Long story short:
I bought a KZ400 a little while ago that I didn't recognize was missing it's front motor mount brackets. Hopped on the eBay and bought a pair with bolts. The ones I got are the right brackets, but my motor is already about a half inch too far forward and a quarter inch too high, so I cannot get all 3 bolts to line up to install the brackets. It doesn't look like I can loosen the top motor mount to readjust everything (looks like it's a single position set-up like the front motor brackets).
I know it was popular on some bikes to loosen these mounts to prevent cracking the case or something like that, but is it okay to ride without the brackets there all together?
I'd like to know because I am literally just buying a chain breaker away from returning to daily riding and my old daily (my Yamaha) just keepings taking a giant dump on me every single time I try fixing something so as soon as I can get a chance for decent money, she's gone - this means I am going to start using my KZ as my daily now.
1985 Yamaha XJ700N Maxim (airhead) - SOLD
1979 Kawasaki KZ400H (LTD), bought with 8416 original miles. - 'Tis my baby
1978 Honda GL1000 - SOLD
1995 Suzuki Katana - SOLD
- KZB2 650
Re: Is it ok to ride without the front motor mounts?
08 Feb 2016 07:30
Not sure but Maybe try loosing the rear and top mounts and then use a round punch to line up....... would have to weaken the frame and all without them all being hooked up I would think.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
08 Feb 2016 09:36
No. loosen all the bolts, put them on with a jack underneath just enough to move the engine around. They are there for a reason.
08 Feb 2016 12:16
Loosen chain or belt at rear axle. or it may never move
- Bowman
08 Feb 2016 12:33
Whatever you've got there its not a matching motor and frame. You sure as hell aint going to jiggle it a bit to pull it back and down 1/32 of an inch much less 1/4 or 1/2. I wouldnt ride it to the corner store.
Honda 55 Trail don't ask me what year, 65? (sold)
79 Yamaha XS400 (sold)
76 KZ750B Twin (project)
72 Honda CT70 (project)
08 Feb 2016 12:53
My 73 350 Honda had a mount on the head. I had to get it on first then fit the rest. I'd get all the bolts started and when they were all in place, I'd tap them in. That engine was snug. Couldn't get the head off without pulling the engine too. Honda was bad for that. Another reason I was sold on Kawasaki's.
- redhawk4
08 Feb 2016 12:55 - 08 Feb 2016 16:18
I definitely wouldn't ride it in case you crack a casting and/or something more painful Go on the net, look at eBay or any other pictures you can find so you can compare what you have with what's needed, it sounds like some things got swapped around between years on the frame/motor/mounting plate front.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
1977 KZ650B1
1980 Suzuki SP400
Last edit: 08 Feb 2016 16:18 by redhawk4.
- Bowman
08 Feb 2016 13:02
If the 400 is anything at all like a 750 twin you got 5 mounting points (6'ish). Rear upper and lower, front upper and lower and a pair tying the coil holder thingy at the top to the frame. I could be nuts but it seems to me if you get *any* pair of bolts put in then if the other 3 or 4 don't slip in you in big trouble. They arent slots they are holes.
08 Feb 2016 13:08
A manual should tell you the sequence of installing the bolts.
- Bowman
08 Feb 2016 13:39swest wrote: A manual should tell you the sequence of installing the bolts.
Absolutely agree that you want to do it by the book.
However if you are mounting *anything* that has more than one bolt hole and the other bolt holes don't exactly line up you have to pause for a second. Add to that the assembly you are bolting on weighs ~150 pounds, itself produces ~30-40 hp and can take you to 80+ mph. Pretty sure I want all the bolts installed and torqued to spec
Prolly an engine swap I'm guessing, should be easy to determine by the engine serial number then if possible fab up some new mounts.
08 Feb 2016 13:54
It's easy to get them reversed or bass akward. :lol:
- YamaKawa
08 Feb 2016 15:00Bowman wrote: Prolly an engine swap I'm guessing, should be easy to determine by the engine serial number then if possible fab up some new mounts.
Numbers on block/casing my KZ's VIN, so I doubt it's an engine swap....
