Wiseco 810 head gasket
  • jimmybon
  • jimmybon's Avatar Topic Author
07 Feb 2016 21:33 - 07 Feb 2016 21:34
#709906
I recently purchased a new wiseco 810 head gasket and found that the end oil gallery oval hole don't line up by 2 mm per side. It came in a packet marked "cometic gasket made in the USA"
Has anyone had this problem before and is there a better brand?
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
Last edit: 07 Feb 2016 21:34 by jimmybon.
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Wiseco 810 head gasket
08 Feb 2016 02:35
#709908
A whole .080 of an inch, oh my. :ohmy:
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Nessism
  • Nessism's Avatar
08 Feb 2016 02:56
#709911
I don't think there are any other brands.
2mm off may or may not be important, depends on where. Those gaskets are very thin in the area around the oval oil restrictors. This is also where the 650/750 engines often weep oil. If the gasket is off in that location I'd send it back and ask for a replacement.
  • redhawk4
  • redhawk4's Avatar
08 Feb 2016 04:15
#709921
Have to agree with Nessim, I'd be worried about the O rings on the oil passageways staying in place and sealing.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
  • KZB2 650
  • KZB2 650's Avatar
08 Feb 2016 04:22
#709925
Imagine you try'd turning it around and if I remember it only goes on one way .... I remember my base gasket and head gasket fitting about perfect....... base gasket has maybe only .080 sealing around the o ring so I stuck it in place with copper coat to make sure it didn't move...........my head gasket came in the piston kit (700cc) and can't remember if it was a Cometic ,,, .... maybe send it back and try Wiseco ?
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • jimmybon
08 Feb 2016 10:40
#709989
Thanks for your comments, I'll send back to the supplier, it must be faulty
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
  • jimmybon
14 Feb 2016 17:07
#710735
I'm not getting much help from the supplier (Serco) Australian importer. He tells me he has 1 in stock so I'm sending him a trace drawing showing him the differance between a ZR750 ( i have left over from the Japanese gasket kit ) and the Wiseco 810cc head Gasket.
The ZR750 gasket fits perfectly and is made up of aluminium sheets, goo and laminated togerther, its vary stiff.
I'm seriously thinking of modifying this gasket as all it needs is to be 69mm bore. being a failed engineer I've roughly designed a punch to cut it out
Has anyone done this sort of thing?
Attachment Headgasketopeneruperer-page-001.jpg not found
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
