1100GPZ UT head - which throttlebody for injection
  • larslykkegaard
  • larslykkegaard's Avatar Topic Author
06 Feb 2016 02:02
#709664
Hello
Has anybody experienced to use throttlebody from newer bikes to get injection on 1100 UT head?? thinking maybe the Suzuki GSXR 1100 or Hayabusa - anyone knowing about spacing on those models or know of other bikes
Engine gonna be 1200-1400cc so not to small
Thanks Lars
  • barney
  • barney's Avatar
Re: 1100GPZ UT head - which throttlebody for injection
06 Feb 2016 03:04
#709667
Hello Lars
What is a UT head?
  • larslykkegaard
06 Feb 2016 05:10
#709692
The Kawasaki GPZ 1100 Uni Track 84 models - we just call them UT here in Denmark
  • barney
  • barney's Avatar
06 Feb 2016 06:12 - 06 Feb 2016 06:15
#709697
The same head was used on the 84 kz1100LTD(also called zn1100)
Last edit: 06 Feb 2016 06:15 by barney.
  • larslykkegaard
06 Feb 2016 10:23
#709716
Well i recon the spacing between the inlet is the same from the Z1 and up to the 84 GPZ 1100 UT...
So looking for injection throttle body from never bike that could fit these heads
  • larslykkegaard
07 Feb 2016 00:58
#709785
The KZ head runs with center to center 75-96-75 spacing right???
  • TexasKZ
  • TexasKZ's Avatar
07 Feb 2016 02:29
#709787
Have you considered Megasquirt?
megasquirt.info/products/diy-kits/
  • larslykkegaard
07 Feb 2016 03:39
#709796
Well recon it would be more fun and cheaper to find something from another model and then play with that..
Just remember something about the old gixxer 1100 had the same spacing as KZ (i think) so could be fun if it was possible to take the system from the newer ones with fuel injection and then mount that if the spacing still was the same
  • larslykkegaard
09 Feb 2016 07:45
#710125
The KZ head runs with center - center - center 75-96-75 spacing right???
