Particles in oil
- pete greek1
Re: Particles in oil
05 Feb 2016 13:25How many miles on the bike ?? it could be just a matter of adjusting the clutch cable, follow the directions in your FSMRoper wrote: I just bought an oem manual for it as well, planning on doing an entire overhaul o the clutch while I'm in there.
Pete
05 Feb 2016 13:33
I would still check the valves and guides. When you drain your oil, if you see shiny particles in the oil like color, you know you have a problem. I did.
05 Feb 2016 21:04 - 05 Feb 2016 21:05Did you get the 650 manual or one for the 750-4? You'll probably need both.Roper wrote: I just bought an oem manual for it as well, planning on doing an entire overhaul o the clutch while I'm in there.
It helps to mention the exact 650 model.
Here's a site w a 750-4 pdf manual & wiring diagrams. mbsween. bike-night. KZ750L3 . Scroll down & click "The Bible" link.
Note: some of the wiring diagrams are mislabeled in the links: the 1981 Ltd is an H2, the 82 is an H3, & the 83 is an H4.
Last edit: 05 Feb 2016 21:05 by martin_csr.
- redhawk4
06 Feb 2016 09:27
I had particles like that in a Honda once it was the timing chain cutting a slot in the cylinder because the tensioner had failed.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
1977 KZ650B1
1980 Suzuki SP400
06 Feb 2016 10:39
I busted a cam chain in 78, all hell broke loose. Went from 903 to 1015. It was cheaper that way and I rode it with stock cams until 86.
- zukdave
06 Feb 2016 16:18
New filter and some Rotella 15w40 and go ride it if the motor was hurt
the filter would look like a bass boat.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- Roper
08 Feb 2016 09:46
Now there is oil leaking from the head gasket on the cyl all the way on the right side.
- zukdave
08 Feb 2016 14:42
Post a pic of the whole bike and one of the vin.# on the motor
so we have a better idea of what you have to work with.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- Roper
- Roper
