77 kz1000 engine build
  • jowek70
  • jowek70's Avatar Topic Author
03 Feb 2016 22:58
#709304
Decided to make a thread after lots of research on this site and several others
My dad has an old kz my brothers and I are gong to make into a great sleeperish street bike
I have access to a great engine builder and want to solidify a few things before dropping the engine off to him
We are running the wiseco 1075 piston kit, porting the head, bigger carbs (not sure which yet), web cams (rec grind #110) and possibly welding the crank.
Am I missing anything ?
This bike will never see the drag strip but will be mainly a stop light racer.
Feel free to share info and knowledge in any form
Look forward to working with you guys
Oh and we added a dynatek ignition already
  • PLUMMEN
  • PLUMMEN's Avatar
Re: 77 kz1000 engine build
04 Feb 2016 01:25
#709307
Clean/check everything internally for wear,including the crank. ;)
  • Brady 154
  • Brady 154's Avatar
Re: Re:77 kz1000 engine build
04 Feb 2016 03:35
#709324
Degree the cams. Makes a big difference IMO.
1976 KZ900 LTD, resto-mod
-1075 Piston Kit
-PSP 3X Cams (degreed to 106)
-Mikuni RS34 Carbs
-Pod Air Filters
-Dyna S Coils and Ignition
-Race Tech Valve Cartridge Emulators up Front
-Ohlins Shocks out Back :)
  • SWest
  • SWest's Avatar
  • 10 22 2014
04 Feb 2016 03:43
#709326
Welcome, pics need pics. :woohoo:
  • jowek70
04 Feb 2016 04:40
#709334
Good to know
Thanks
Only pics we've got so far
  • SWest
  • SWest's Avatar
  • 10 22 2014
04 Feb 2016 04:49
#709336
I like the Z1 styling. If you really want a sleeper, go with the 4/4 pipes then leave em in the weeds. :woohoo:
Steve.
  • Nessism
  • Nessism's Avatar
04 Feb 2016 04:51 - 04 Feb 2016 04:52
#709337
Heavy duty clutch hub rebuild. Check KZ Zone at APE.
Oh, and send the crank to Pearson or Gardner (spelling?).
Last edit: 04 Feb 2016 04:52 by Nessism.
  • DFIGPZ
  • DFIGPZ's Avatar
04 Feb 2016 11:31
#709381
cam Rollers
HD Clutch Basket.
Backcut Trans.
Weld Crank.
1984 750 Turbo
  • pete greek1
  • pete greek1's Avatar
04 Feb 2016 12:23
#709389
I guess it all depends on how much you want to spend, I have a 1075, back cut trans, ported head, Mikuni RS 34's, Dyna ignition, wires & coils
& stock cam"s, V/H header, K& N pods, & it's plenty fast, & I have sprockets geared for the highway , if you do what your planning on doing so far, & just change your sprockets to 1/4 mile gearing you'll be surprised at how fast it'll be,
& if it's not fast enough , go for a Turbo kit, B)
Pete
  • jowek70
05 Feb 2016 04:48
#709471
Great to hear
A more acceleration oriented gear ratio is what we were planning on doing
  • jowek70
26 Feb 2016 12:28
#712603
Any recommendations for clutch plates?
  • 9er rider
  • 9er rider's Avatar
  • Keep a cool tool
26 Feb 2016 18:50
#712662
HD camchain HD valve springs
