Need some opinions please - cyl head washers
  • 79MKII
  • 79MKII's Avatar Topic Author
  • Love Them Kaws!
07 Jul 2006 21:20
#60109
I am preparing to reassemble my engine and have a question regarding the cylinder head washers. According to Kawasaki, I need 4 copper washers and 8 steel washers. I had copper for all 12, but they are $4.00 each from Bike Bandit! Should I go with all copper or is it ok to use the steel on the other 8 studs? Also, does anyone know where these can be bought other than a dealer? I thought APE might offer them with their cylinder head nuts, but I haven't been able to find them. You help would be appreciated.
Thanks!
The Kaw List:
  • modprod
  • modprod's Avatar
Re: Need some opinions please - cyl head washers
07 Jul 2006 21:31
#60112
The 4 coppers go on the 4 corners but I have used copper on all 12 for years.........mod
  • savedrider
  • savedrider's Avatar
  • 1975 Z1-B 900
07 Jul 2006 21:42
#60114
I used copper washers from www.mcmastercarr.com . Lots cheaper than the dealer price.
Get right or get left! <*{{{><
  • 79MKII
  • Love Them Kaws!
25 Jul 2006 17:06
#64679
Well, I FINALLY got around to measuring my copper washers and got them ordered from Mcmastercarr. They were a little over $1 each vs $4 each from Kaw. I also needed a specialty bolt that they have in stock, so I ordered that too. I just went ahead and got copper for all 12 studs. Thanks for the tips!
Is it OK to re-use cylinder head bolts? Mine are from APE and were never taken apart until now. They don't look too great (rust), but I'm sure I can clean and paint them if they are OK to use again.
The Kaw List:
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
25 Jul 2006 17:24
#64684
Interesting they are available from mcmastercarr. A good tip. I horde the old copper ones and always use copper on the engines I rebuild. The reason for the copper on the outside studs is the oilways coming up the stud holes in the cylinder block on the outside studs - the copper washer provide a better seal as they crush down (as long as you anneal them).
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
27 Jul 2006 12:53
#65204
How and why do you anneal them. Can you reuse a copper head gasket this way?:side:
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • wireman
  • wireman's Avatar
27 Jul 2006 13:00
#65206
you anneal them by heating them uo really good and tossing them in a bucket of water.this swells them to origional size and softens them.you can do it with a copper head gasket but its harder to control the thickness .
  • BARNEYHYPHEN
  • BARNEYHYPHEN's Avatar
28 Jul 2006 13:36
#65462
I normally hang 2 or 3 together on a long hook made from an old metal coat hanger. Heat them up with a propane torch till they are "cherry red", they will glow bright red, then drop them in a bowl of cold water.
