Valve clearance after valve job 1982 GPZ750
- bountyhunter
Re: Valve clearance after valve job 1982 GPZ750
30 Jan 2016 13:28 - 30 Jan 2016 13:29Madtrout wrote: "Good machine shop" is certainly the variable here...
Sure is. The shop that did my head actually set it up so the clearance was the same as before so I could use the same shims. They must have shaved the ends of the valves just right to match up the original height. But I did ask up front to make sure and not change the clearance.
Last edit: 30 Jan 2016 13:29 by bountyhunter.
- zukdave
30 Jan 2016 13:46
APE valve height gauge is a good tool for tipping valve's.
I heard that if the stem is cut to much the bucket will hit the spring retainer
and let the keeper's out.
racetoolz.com/
racetoolz.com/
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
30 Jan 2016 14:41 - 30 Jan 2016 14:42
It's in the manuals. It would take a ham handed moron not to see it and take off too much. It must have happened, that's why the warning. :pinch:
Last edit: 30 Jan 2016 14:42 by SWest.
- zukdave
31 Jan 2016 16:20
Some time's it's not the ham handed guy it's the dude in the race shop
trying to find room for the stupid big valve's, huge spring's and monster size cams.
Some time's you get the math wrong and part's have sex.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
31 Jan 2016 16:37
:lol: :lol: :woohoo:
- Madtrout
01 Feb 2016 06:00
Talked to the machine shop today, told me to bring it by for tipping the valve stems. I'll let you all know how it works out. Thanks for all the advice, Mark
- Madtrout
11 Feb 2016 15:22
Got the head back today. The machinist tipped the valve stems and kissed the keepers. Plenty of clearance now, He set the shims a bit loose for my taste, so I'll bring clearance to .178mm and put it all back together. Thanks for all your advice, Mark
