Recommended valve spring compressor?
  • Madtrout
  • Madtrout's Avatar Topic Author
17 Jan 2016 06:37
#707006
Can anyone recommend a squeeze action valve spring compressor to work on a 1982 GPZ750? Seems my machine shop wasn't quite as antiseptic as I would have hoped. The buckets seem to encounter grit going in. I want to disassemble the valves and clean it up better. Thanks in advance, Mark
  • Nessism
  • Nessism's Avatar
Re: Recommended valve spring compressor?
17 Jan 2016 06:41
#707007
There are all kinds of inexpensive compressor kits on ebay. If you want to go even cheaper just purchase a large C-clamp (about $8 at Harbor Freight) and a chunk of PVC pipe. Cut a little window in the pipe and go to work.
  • cafebrat
  • cafebrat's Avatar
17 Jan 2016 12:15
#707058
^ i just removed my valve springs and used a large c-clamp and a socket i cut a window into. Worked great and didn't have to go buy any special tools
83 Kawasaki Kz1100 LTD
81 Honda cm400
72 Suzuki T500 Titan** 2-stroke B)
  • diggerdanh
  • diggerdanh's Avatar
20 Jan 2016 04:25
#707362
The Lisle Valve keeper remover and installer kit. I learned about this type of spring compressor over the summer and bought the kit immediately. I used it on my KZ400 heads, piece of cake to remove and install. Easy to use, I love it. I've seen videos of them being used on smaller engines and SBC heads.
This is the full kit at around $58:
amzn.to/1n9C8JY
but you can buy the smaller or larger separately for about $35.
