GPZ750 A2
  • Rob69
  • Rob69's Avatar Topic Author
GPZ750 A2
16 Jan 2016 09:19
#706926
Hi all,,
My Gpz750 has suddenly developed a rattle.
On further investigation i removed the rocker cover to inspect the cam chain and also tested the cam tensioner both of which seem fine. Turning the engine over with a socket i can hear a rattle / tap as soon ad the crankshaft is moved.
I could here the noise from under the carb area.
I removed the starter motor and then found that the starter gear inside the engine has alot of side to side movement. IS THIS FAULTY OR EXPECTED PLEASE.
Thanks Rob
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: GPZ750 A2
16 Jan 2016 14:10
#706953
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
