New spark plug wires
  • blink543
  • blink543's Avatar Topic Author
12 Jan 2016 16:45
#706506
So I want to replace my older spark plug wires with new ones. Irk how to go about doing this. I see online there's wiring, wiring with ends and without ends. The ones I currently have are 7mm copper core
Adam james
  • Nessism
  • Nessism's Avatar
Re: New spark plug wires
12 Jan 2016 17:00
#706513
Purchase 7mm copper core wire
Purchase new NGK plug caps
Caps unscrew from wires. Wires unscrew from coils.
Squirt a little WD-40 underneath the outer wire protection sheath and pull them off.
Cut new wire to length and install protection sheath over top of new inner wires.
Screw on new plug caps and attach wires to coils.
Crack a beer and toast completion of another project.
[IMG
[IMG
  • blink543
12 Jan 2016 17:17
#706514
Nessism wrote: Purchase 7mm copper core wire
You mean only the ngk caps unscrew or is that common for all spark plug wire ends?
[IMG
[IMG
Adam james
  • kaw-a-holic
  • kaw-a-holic's Avatar
12 Jan 2016 17:25 - 12 Jan 2016 17:28
#706517
Blink-
The NGK caps like the ones pictured unscrew. Last I checked you could still buy them from O'Reilly Auto parts. There are other types of spark plug ends but they are the crimp on type and require a special crimper to do them correctly.
Additionally, your coils may be different. The coils I had on my 77 KZ1000A1 had the wires permanently attached. Can you post a picture?
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
Last edit: 12 Jan 2016 17:28 by kaw-a-holic.
