Anyone know kz440 piston compression height?
  • 13bravo
  • 13bravo's Avatar Topic Author
08 Jan 2016 17:46
#706020
Just wondering if anyone had the compression height measurement of a KZ440 piston. I have to tear the jugs off anyways as I'm certain the rings are sticking in the number 2 piston. The cylinders are also quite glazed anyways so I'm going to at a minimum deglaze the cylinders and change the rings. If I have to hone a few thousandths out I will probably just knurl the pistons instead of trying to find a set of decently priced oversize pistons.
I already have a slight battle trying to find some new valves, the tip on one of them has a badly worn dimple that if I tipped it would probably be in the .060 thousandths range of material removed.
I'm also going to change the guides to a bronze guide. I already have a bunch that will fit correctly.
1983 KZ440-D
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Anyone know kz440 piston compression height?
09 Jan 2016 05:01
#706038
Check the link I posted on your other post.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
The following user(s) said Thank You: 13bravo
